Just replaced most of the handbrake cable, did'nt do the bit into the car but did the rear and the 2 to the wheels. Alo replaced rear shoes.
Ive set the cable as per the AR manual ie there is less than 1mm endfloat on the 2 plastic stops which protrude from each drum. They are also not tight.
Trouble is the handbrake is crap. Comes up about 8 notches but wont lock the wheels , i set the shoes on the adjusters so they are just rubbing the drum but not happy with handbrake , any sugestions please?
Russ
Russ
. trying to undo the knurled adjuster here’s how.
