My Maestro 1.3 has developed an annoying habit. It will be running fine for a couple of miles from cold or warm start and then decide to run erratically. It has always ran like a dog which I put down to the vacuum pipes. However it is now stopping completely when approching lights or a junction or roundabout
. The engine will cut out completely when approaching a standstill and the battery light comes on. It will start on a turn of the key but will splutter for a bit then come to a standstill a moment later. I have noticed the engine is a lot noisier than it used to be when exceeding 45-50mph in fifth gear. It has done over 91k miles. I have tried the simple screwdriver fix by removing the rocker cover and turning the cross head mixture screw clockwise to increase revs. The engine sounds as if it over revving then dies completely. I suspect a faulty electronic control unit or the vacuum system and am hoping it will be a straightforward fix. Any ideas gratefully received. Cheers
