hi there
had a maestro 500 van on drive over winter started it after a month to take to garage to get water pump fixed as it was leaking previous to buying topped up with water it started flooding from rear of engine block found out it was one of the engine plugs like a bottle cap has popped out
i cleaned the cap and then with some sealent fitted it back in the hole this done the trick unless this was wrong?
left it for a few days to go off then i filled with water started the engine then staight away all the water was coming from the top of matrix some where into the foot well drivers side i checked the two water hoses passenger side that come from the engine into the van to the matrix they were fine and not leeking is there another escape route for the water to leak
unfortunatly i have got back trouble after a previous crash in a tandy van and are limeted to twist under the vehicle to see anything
wondered if there was a easier solution instead of ripping out the whole console to see this magical waterfall
thanx
kind regards
lucky jay
thanx
kind regards
lucky jay
