elrctric windows on van
  • elrctric windows on van
    hi there
    electic windows were working then they stopped
    then the van was sitting for a while wouldnt start got it going
    the widows started working now the left side is still down the right side is up ive got power in switches fuses tested with tester
    the electric mirrors work but when engine is on it blows the fuse
    now its raining joy
    any help welcome
    thanx
    Try slamming the door whilst holding the switch in the up position. If this works the motors want a good clean out or replacing.
      electric windows
      hi there
      tried slamming the door nothing
      left the van for a couple of days and the drivers side started to work but not the passengers then i had some lovley smoke coming out of the drivers mirror (a few blows and it went out)
      turned off egnition now nothing i will take off mirror tomorrow have a look and will remove the motor for the n/s window out
      if this is possible as to clean it ?????????
      thanx for advice
