Erm-Hello--this is my very first visit--and post, so I hope I'm doing it right! Now, I own a B reg 1300, 24,000 miles Austin Maestro for which I have very carefully lost the only set of keys!!! Any ideas as to how/where I might get new keys cut, or supplied for the existing ignition/ door/noot locks (bearing in mind that the ignition key also opeartes the two front door locks) WITHOUT necessarily having to replace the locks? Is it still possible to get sets of keys from the appropriate Main Agents (are there any left representing Rover!!) using registration and or Vin Numbers? ANY advice would be gratefully received--basically HELP!!!
I have located a Company who can, if necessary, cut keys to suit the locks, but that means I have to take in the appropriate locks, which in this case would mean removing (and later re-fitting) the existing ignition lock, and the Boot lock (easy). I am prepared to do this as a last resort--but just wondered if there might ne an easier way first====over to you guys!!
