Anyone got any photos they can upload of their carbs, please? Pics from any angle would be of use -including the standard airbox.
The reason I ask is that:
a) Nick spotted that one of the twin choke Webers has a clear plastic pipe on its rear side that appears to link two 8mm long metal pipes (pointing rearwards). However, the other carb did not have this, although one of the 2 pipes was sealed with a bolt down the plastic pipe (the other metal pipe was too close to other stuff to get at its open end, so it is suspected that this may still be leaking air into the carb and causing a bit of rough running.
b) The induction roar is deafening with the current foam air filter (and no airbox) + it also sucks hot air into the carbs so we are considering making an airbox for it to solve the noise/air density issue
This is the car in question, FYI:
http://www.maestro.org.uk/forums/sho...787#post144787
