a strange squaking noise has appeared on my car today.
coming down the motorway if I moved the steering slightly to the right, even just a little bit there was this rapid on/off squeaking sound you could hear in the car. with the window down you can hear it louder. With the wheel held slightly right there is no noise. also if you slightly press the brake - even just a fraction it stops.
I was wondering if this could be a bad CV joint; as in addition to the above, when i accelerate out of a junction turning right there is a horrible kind of rubbing sound - its nothing touching the wheel so i assumed it was a bad CV
Any thought on a solution would be appreciated?!
Andy
Andy
