i need a fuel tank for my petrol 1300 maestro, i have located a tank but its off a diesel 2 litre maestro is it interchangable ? can anyone please advise
fuel tank swap ???
Yes you can use it. you'll need to block off the extra return pipe on the top of it though. (bit of rubber pipe with a bolt jubilee clipped in it works well I find!)www.maestroturbo.org.uk - The Tickford Maestro Turbo Register
