Just checked the wiring diagram and yes it does go through the ignition so car has to be running or on posit 2 (3 is to turn the starter, i think)
Anyway there isnt much to the stop lamp circuit.
get a meter.. put it on dc volts check three places.
Put negative on a good place on the body (or a wire to the neg of the battery)
Start the car.
then put positve in the fuse box slot with the fuse out (check both sides). Do you get a reading on one of them? 12-13.5 volts ish.
If yes, put the positive terminal of the meter on the brake light swich, press the peddle any voltage?
If yes, get someone to sit in the car and pree the peddle...check the multiplug at the back to confirm voltage there.
Start the car.
