hello guys, was helping out andy today with his turbo re its running issues -
what i found so far was:
couple of carb hoses wrong way round and a split vac hose from carb to ecu. sorted this out and changed to a set of new plugs i had lying around.
Took it for a spin and it was much better - but is still running very very rich. The new plugs were sooty black after about 10 miles.
air filter is ok and ignition system looks good. car doesnt feel down on power but lumpy on idle with the mixture.
So, i was thinking fuel preesure reg - looks like the screw has been moved at some point? or is it possible for the auto choke to stick on? last thing could the incorrect needle valve do this?
I have a spare untested pressure reg i got with 251 - so maybe worth a try.
was even considering swapping the full carbs over Lol to try and narrow it down
cheers
chris
cheers
chris
me want one lol.
started up straight away then would cut out every time I tried to move. The AA bloke found a screw sitting on a tray under the carb, didn't know what it was, didn't seem interested to find out and just towed me home.
