I just got the engine running on my 1985 MG Maestro - not started for 20 years. It sounds really good but it only runs for about 30 seconds and then cuts out. It will start immediately but then does the same again. There is fuel getting to the injectors. I have cleaned the fuel tank, replaced the fuel filter, replaced the plugs, injectors cap and rotor arm.
Any suggestions gratefully received!
