Maestro Turbo misfire
  • Maestro Turbo misfire
    Hi, can anyone help? My Maestro Turbo starts and runs ok but starts to misfire at 3000 revs. When it gets past that it runs and accelerates fine. I thought it might be the carb but swapped that and the problem is still there. Any ideas?
    Things to check:
    Balance pipe on the carb - tiny splits can cause issues
    Rotor arm spinning in the bush means it isn't in the right position so the gap is too big to jump
    Rotor arm itself - 3k is about where the turbo spools so where the igntion system is worked hardest.
      Thanks for the reply. Will check it out and let you know. Cheers, John.
