Question 1
These cylinders are sold as 'handed' ie left and right sided.
Can a 'left' cylinder become a 'right' one by taking out the pistons and seals and simply swapping these over? One piston is grooved for the brake shoe, the other isn't.
These cylinders are available (cheap) here
http://www.ebay.com.au/itm/AUSTIN-RO...-/400506004505
Question 2
Are Maestro cylinders interchangeable with Montego cylinders?
I understand that the Maestro cylinders are 15.9mm and the Montego 17.5 mm or 19.0mm, - in which case, of course, they are not compatible.
They are available here
http://www.ebay.co.uk/itm/AUSTIN-ROV...-/360673211986
Your thoughts, advice, comments etc all very welcome.
My blue EFi 2.0 is up for its MoT soon and I suspect that one of my cylinders may have a 'weep'. I may just swap them both anyway, to be 'safe'.
Thanks,
Peter
Question 2
Thanks,
Peter
