are the front suspension arms the same both sides? need a l/h one but found a r/h one that looks the same, once ARB link and ball joint are removed. cheers martin
I'm not 100% sure but as you say I think they are the same once the balljoint is removed. I don't think the bush mountings are off centre.www.maestroturbo.org.uk - The Tickford Maestro Turbo Register
As I say I'm not 100% sure but I can't remember them being non symmetrical. I.e. you'd simply be inserting the ball joint upside down and swapping its side i.e. rotating it 180 degrees clockwise. Obviously this can only happen if the arm is symmetrical about its longitudinal axis which is the bit I can't remember for sure as I've not got one infront of me.www.maestroturbo.org.uk - The Tickford Maestro Turbo Register
Originally posted by BIGDAVE View Posti seem to remember the early ball joints was handed.but the same on later models
The arm was never listed as a separate part, only an assembly with the joints riveted on, so I can't check that way either.M&MOC Committee Member - Archivist
I've got some new arms in the garage somewhere. If I can get to them I'll have a look if they are different.www.maestroturbo.org.uk - The Tickford Maestro Turbo Register
