power steering pump
    Rimmers also sell a pump for the Rover SD1 V8, it's exactly the same as the 2.0 Mont/Maestro one but a bit taller, I installed works a treat. Take a look at the photos. That pump is easier to find elsewhere too. Click image for larger version
Name:	power steering pump1-vert.jpg
      Thats a good idea. Thanks. Probably the solution I will go for untill a new one pops up. Dosent look quite right but long as it does the job. I take it this is it?
      https://rimmerbros.com/Item--i-ERC6969
      Thanks Andy
      MG Maestro Turbo #500
      Rover 218 VVC Coupe
      MG TF
        Thanks Andy
        Hi, yes that looks right, you get a small 'dent' in your bonnet insulation but it fits OK. Click image for larger version
          Yes I checked the invoice I have, it is ERC6969. You can always find a secondhand original pump in Spain, I've bought 3 or 4 there over the years, they go for about £25.00 + shipping, usually about £15.00 for that. If you need help for that let me know.
            Ok thanks. Strange they are for sale in Spain but doesn’t seem to be any over here for sale. In fact, the only one I have found for sale is in Spain:
            https://www.b-parts.com/en/store/pro...993-1994-1995/
            But it’s a bit pricey for a secondhand unit. Though it should have some life in it I would have thought if its only done 70000 miles. If you know of one you could post around about what you have said I would be very grateful, just pm me. Not sure how changing the covers over from
            QVB10016 as Robert suggested would work as that hasn’t got a reservoir and looks different. Thanks Andy
            Rover 218 VVC Coupe
            MG TF
              https://www.milanuncios.com/otros-recambios/bomba-direccion-rover-montego-20-g-20h-361502644.htm
              https://www.milanuncios.com/otros-re...-361502128.htm
              https://www.milanuncios.com/otros-re...-361501845.htm
                https://www.ebay.es/itm/392913490399?ssPageName=STRK%3AMEBIDX%3AIT&fromMak eTrack=true
