I am after a little help Mechanically with my 1.3 engine, it has stopped running properly!!!
It would run fine when it was cold, but when it got up to temperature it looses power and stops!!
I have checked the coil, HT Leads, Distributor cap and rota arm and i'm getting a good spark from all four.
I have checked and have good compression on all 4 cylinders.
I have checked that the fuel is getting to the carburetor and that is all good.
I have taken apart the carburetor and that was all clean with no blockages.
But now i cant get it started at all, i am a little puzzled by this so any help would be welcomed, with both parts where it was only running up to temperature and now why it wont start.
Many Thanks
Rob
Many Thanks
Rob
