Hi all
Got a Rover Maestro 1.3 A Series with a manual choke (Hif44 i think)
Bought it from an old fella who has played around with the carb setting and i just cannot get it to drive properly
All of the vacuum lines are hooked up, although the one on the inlet was capped off with a screw
It idles fine, but bogs down with no real power when trying to drive it, ive checked the dashpot has the correct level of oil and cleaned the inside of the assembly. Checked that the float isnt stuck and is all nice and clean
Any ideas? thanks in advance
