I was delighted when I used my AR Speed Check for the 1st time (properly
) to see all the correct lights appearing. The transducer light showed that there was some issue with that unit. I recently changed the speedo cable and that fixed the previous one's habit of dancing around the speedometer
it's still showing an optimistic reading, for example when speedo shows 100KPH it's actually only doing about +- 90KPH. Would the transducer be responsible for that ? The speedo cable goes directly to the traansducer. I do have a spare transducer. Any info or help much appreciated, Chris
