Creaking Clutch Pedal
  • Creaking Clutch Pedal
    I have recently started to experience the delights of a clutch pedal that creaks and clicks (possibly old age setting in!) when depressed and released on changing gear. Is this a sign of imminent failure of part of the pedal mechanism?
    Any advice on how to repair would be appreciated. Car is a 1987 1.6L Maestro.
    Burgundy 1987 Maestro 1.6L
    173,000 miles.
    Mine has done that on and off since I bought the car 3 years and 45,000 miles ago. It is currently not doing it but was doing it as recently as a couple of months ago.
    I've tried spraying WD40 on the pedal mounts etc. but it did nothing other than stink the car out.
      Originally posted by D813YBB
      I have recently started to experience the delights of a clutch pedal that creaks and clicks.
      I had this trouble and it turned out that a bit of the carpet had got tangled up in the mechanism.
      You can contact me by clicking here.
        I had the same thing and WD40 did work!
          Same here: WD40 worked but only after I'd put two lots on.
          Steve H
            I'll give the WD40 a try. Is it a case of lying upside down and try and locating the clicking part?
            173,000 miles.
