I noticed fluorescent green fluid dribbling down from the rear suspension turret today. Upon removing the plastic trim over the shock absorber more fluid could be seen. Presumably this means I need a new shock absorber, so are they still available and is it a DIY job to replace it?
Broken Suspension?
Yup, like previous posters said, it's a DIY job but don't skimp on the spring compressors - it is possible to kill yourself or anyone nearby if it all goes wrong, or at the least severely injure yourselves - or cause serious damage to a brick wall if you are unlucky, for example. But don't worry about that - invest in proper spring compressors with a sintered finish, and all will be fine .
Regarding the bottom bolt, start spraying it with Plusgas at least a week in advance and spray the thread, bush inside the trailing arm and bolt head. Do this daily (douse the whole area), and the bolt should come out easily on the day .
It's strongly recommended that Shock Absorbers should be changed in axle sets.
As regards buying Shock Absorbers, Motor factors can still get hold of them, but eBay is your friend and will be cheaper (I paid £25 delivered for a full set a year ago) .Rich Smith
You can email me here
REAR springs/shocks.
Originally posted by G733-KKWYep you have an issue there...
Nice and easy. using only PROPER spring compressors no halfrauds
no ratchet straps , etc etc ! .... Coils + Head = No head. {or Damage to other .. roofs.. windows.. etc..}
Has one of my posts been deleted off this threat.. about id advise the pair too , but thaught it was one of those things as a "money grabber" all us mechanics appear to be.. ?! and about the roof hole at work..
true.. wen we lowered the special we only just put the compressors on , for saftey ..
Originally posted by G733-KKWHas one of my posts been deleted off this threat.. about id advise the pair too , but thaught it was one of those things as a "money grabber" all us mechanics appear to be.. ?! and about the roof hole at work..
Which one?
I’ve just been informed by Partco that they have two types of rear damper for the Maestro as follows:
Gabriel 51411 157mm spring height - £25.59+vat
Gabriel 51028 181mm spring height - £20.28+vat
Could anyone shed any light on which version to get and should they be replaced as a pair or just the damaged one?Burgundy 1987 Maestro 1.6L
173,000 miles.
Originally posted by D813YBBCould anyone shed any light on which version to get and should they be replaced as a pair or just the damaged one?
Hi, you do not have to replace the rear dampers in pairs if you were fitting exactly the same unit as what is fitted to the other side. i.e unipart unipart, or monroe monroe etc. etc. and the opposing damper is in perfect condition. If you are not at all certain then you should replace both for the sake of saftey and ride quality.
PS you do not need to use spring compressors on the rear. Only the fronts on maestro montego need compressors.
The spring compression on the rears is released well before the securing nut is removed,
Originally posted by D813YBBI’ve just been informed by Partco that they have two types of rear damper for the Maestro as follows:
As G Force says, changing like for like will be fine. If you can find the same make of shock absorber that is on the car now, this would be an easy way out of the immediate problem by changing just one .Rich Smith
