Help!
My Maestro Turbo won't boost. There's a noise like a vacuum cleaner then a lot of "chatter". I couldn't find any leaks, so I took the wastegate actuator off the turbo to check it out (the drum shaped bit that sits on the turbo) When air is fed into the inlet pipe it's supposed to move the actuator rod, but the air is escaping past the bush which the shaft runs through. Could this be my problem? The unit seems sealed - can the bush be replaced? Anyone got a spare one for sale?
Phil
Phil
