With the showers of rain we've been getting recently i have discovered a leak from the roof of my car (or more so it has discovered me!) well several but this leak is kinda annoying me alot.
it is located on the drivers side where the arial is at the top corner and has a tendancy to nearly rain indoors when driving.
it isnt the window seal. obviously it leaks more when the rain is heavier. i have thought of removing the arial thingy and covering/filling it as im not too bothered about listening to the radio anyway or bunging the gaps up with some kind of window sealant. has anyone had a go at trying any of the above...will it look any better or worse without a arial?
emma.
it isnt the window seal. obviously it leaks more when the rain is heavier. i have thought of removing the arial thingy and covering/filling it as im not too bothered about listening to the radio anyway or bunging the gaps up with some kind of window sealant. has anyone had a go at trying any of the above...will it look any better or worse without a arial?emma.
i didnt have time to take out the roof lining this weekend. i have a feeling the leak will be coming from/or both the windscreen seal or the rubber strip on the roof.
