I have an enquiry from a member whose 1989 Montego 2.0EFi is running erratically (misfiring, not staying running, but a little better when warmed up). The garage working on it think the ignition ECU has gone, part number NNN10005. I don't have that part number, but I do have NNN10001, so my questions are:
1) Is the ignition ECU likely to be at fault?
2) If I can't get hold of NNN10005, would any other ECUs be suitable. The ECU is not the original for the car as it was swapped to change to run on unleaded fuel.
