hello ,
can anybody tell me what is the difference between the outer cv joint for a 1994 montego clubman estate 2.0 TD and other montego 2.0 petrol versions?
my car needs a new outer joint and could not find any on Ebay as out of the many cv joint listed all of them said that they would not fit my estate 2.0 TD but would be ok on 1.3 / 1.6 and 2.0 petrol montegos .
I then found a local car accessory shop that said could supply me with this part for £50 .
I bought it but when I attempted to fit it on found that the new part had a bigger diameter on the outside than mine and 32 splines on the inside whereas mine had 22 .
(the splines for the wheel hub were 25 same as mine .)
The shop told me that according to my number plate they had supplied the correct part .....but I know that this driveshaft is the original that came with the car when it was new , shop owner said you cannot argue with the computer !.
I looked on ebay again and found some CV joints with same splines as mine 25 outside and 22 inside but they state that they are not suitable for estate cars ............I find it strange that a shaft should be different for an estate car than for a saloon car?
I am still waiting for the shop to contact me to tell me wheter they have found a suitable CV joint
I will be grateful for any of your opinions
