I have had an issue with my MG Montego for almost a year now and am no nearer solving the problem.
The car runs perfectly for the first 2 to 3 miles and then develops an intermittent hesitation which I have not been able to cure.
It may be coincidence but the problem seemed to appear after I replace the ht leads, coil, distributor cap and rotor arm. The issue did not seem to get any worse and sometimes almost disappeared. However a few weeks ago the car stuttered to a halt and had to be recovered. I found that there was no spark at the king lead and replacing the old distributor cap and rotor arm cured the problem but the hesitation was still there.
I have replaced the ht leads with the old ones, changed the coil twice and replaced the crank sensor. I have also swapped the ignition ecu. I am getting no further trying to solve this and am looking for inspiration please!
Ray
Ray
