I plan to replace my shocks on my Montego VP EFI and was wondering what other parts are likely to need replacing at the same time. Also, will I need any special tools? I have spring compressors
Suspension rebuild
you might need these, I think they will need the gaiter cut down.
https://www.ebay.co.uk/itm/330584941...Bk9SR4KrzPvdYA
https://www.ebay.co.uk/itm/290581106...Bk9SR-qTwPvdYA
I think I will need these. Please add anything I may have missed:
Rear
2X top mounting upper rubber bush - Rimmer Bros?
2X top mounting lower rubber bush
2X upper spring metal cup rubber insulator ring
2X bump stop spring aid - eBay kit
2X damper push rod dust cover - eBay kit
Front
2X top mounting rubber bush - Rimmer Bros?
2X strut top bearing
If any of the above also hold up well can can be reused, please let me know. I doubt though that these have been replaced in a long time though if ever
