I found the T peice on the vac pipe broken and although have got new bits in a box coundnt be arsed to go through all the boxes to find it but had some small Hozlock T pieces from a micro bore watering system for the greenhouse .I pushed on 3 pieces of the tubing onto the Tpiece then pushed the vac pipes into these.The vac pipes are not as a tight fit so put a sealent round the pipe to make them air tight and seam to be working ok .
Alternitive vac pipe connectors
Sure & steadfast.
1979 Triumph Dolomite 1500HL Pagent Blue From new 76.000 milesNow out of Hibination and into RestorationTags: None
As pointed out to me this fix may not last due to the heat but we will seeSure & steadfast.
Just an update.it is over a year now and the Hozelock connectors used are still working perfectly ok with no signs of the heat affecting the plastic.Sure & steadfast.
