How much would it cost to renwew the headlineing on a maestro
Headlineing
I would do it myself .Do the colours vary from model to modelSure & steadfast.
If you go to one of the shows, autojumbles you can buy top quality headlining material for between £6 - £10 metre. You need 64ins x 48ins to do a Monty so prob less to do a Maisty.
So 2 metres MAX of the roll which is usually wider than 48 ins.
With a tub of glue you are looking at no more than £30 to DIY ...not £60!
Even online - say at Woolies - you can get Dove Grey headlining at £12.40 metre including VAT.
not that long ago they had this on offer at £6 a metre!
http://www.woolies-trim.co.uk/c-93-brushed-nylon.aspx
No, it doesn't have to cost a lot if you DIY. And best to get the sandwich type ie: with a linen backing on the foam, 'don't' get the bare foam backed stuff.
Originally posted by Russ View PostI got some heavier duty stuff fitted to mine, a company called moore's of Aylsham did it
Wollies dove grey seems abit dark to meLast edited by TLC; 24th August 2009, 12:03.Sure & steadfast.
Just found it, www.moorestrim.com or 01263 734582 or 07795 682628 his name is paul real decent chap and tell him I sent you
Did all the Maestros and Montegoes have the same colour headlineingSure & steadfast.
The PVC headlining was whitish, although that on early MG1600's was a dark grey colour. Later fabric headlinings were either cool grey for blue/grey trim cars, or warm beige for beige/brown trim cars. MG's also had a darker grey fabric headlining for a while.M&MOC Committee Member - Archivist
[QUOTE=stellaholic;105651]There is a brand new one on ebay for £190 :
Shall i get it in casei buy a MaestroSure & steadfast.
this one is good its a little bit light but otherwise ok. make sure you use the right glue thoughi didnt and i fell off in the heat. I have brought the right glue from him now just got to get a round to doing it again
http://cgi.ebay.co.uk/3m-x-1-4m-Ligh...d=p3286.c0.m14
as you can see it was just starting to come off
