It looks great lads..!
Gooon - Teaser pics
Been a while since this was updated and Gooony had a face lift before this July's RS Combe. A full respray is planned later on in the year
Little vid on track, including loosing the back end on oil after leaving the pits
http://www.chippers.me.uk/gallery/go...nminiworld.wmv
Some changes are happening (although a broken rib is going to slow me down getting them done)
New lightweight dash
Complete rewire of the car
Poly carb rear window
New rear bumper and diffuser
Wilwood pedal box
CP5200 calipers, bells and rotors
Change of cams and cam timing
More boost
Relocation of oil and turbo cooler
Electric water pump
All the changes to the shell are to reduce weight by shortening cable runs, pipe & hose lengths, lighter materials etc as the engine is getting near the limits of power we can effectively put through the front wheels
Should be over 420bhp per ton when complete
He stripped it and bought a ZR, there's a build thread on RoverTech that's recently been updated. You may need to register to see it.
http://www.rovertech.net/forum/viewt...32701&start=70
I believe another chap bought the Goon shell and is rebuilding it.
I know the ZR is a close relative of the the Maestro but having owned both the maestro is so much easier to work on. When I had the ZR the rad needed changing, oh a 10min job I thought. No half a bloody day, you can't undo the slam panel like you can on the maestro.
I'm glad this shell has gone to a good owner and will see the light of day again
Good to hear it's still around.... Thanks Ben!
Looking forward to seing some upto date pics.
Al
