According to the Haynes driver handbook thing, some models had a 12 hour clock and some had a 24 hour clock. Does anyone know when the 24hr variant was introduced/cancelled, and if you can tell which is which by looking? Alternatively, am I being led up the garden path?
24 hour clock
24 hour clock
PA02DXB - Rover 75 2.5 Connoisseur SE auto - Bought because it was cheap. Fleet getting out of hand now.Tags: None
I think that you might be being led up the garden path. Both the earlier vacuum flourescent clock DRC 9250 and the later green LCD clock EEP 55 (VIN 345416 on) are 12 hour timepieces. There is no mention of a 12 or 24 hour variant. The later orange clocks (Oct 1988 on, EEP 122) could be 24 hour items. In the Haynes handbook it refers to 12 or 24 hour clock operation. This is because your book was published after the 1989 MY facelift and as a result was updated (somewhat misleadingly) to cover the later model's 24hour capability.
That's how I understand the situation anyway. I've had an 85 Maestro, a pre-facelift 88 Montego and an 89 Maestro - all kept time on a 12 hour basis.M&MOC Committee Member - Archivist
From memory wasn't there an option on the later clocks to swap between 12 and 24hour by holding down one (or more) of the buttons for a set time period.www.maestroturbo.org.uk - The Tickford Maestro Turbo Register
The orange ones from facelift Montego may have been able to do this, by deprssing both H and M buttons simultaneously. My trafficmaster clock has this feature.Originally posted by E_T_V View PostFrom memory wasn't there an option on the later clocks to swap between 12 and 24hour by holding down one (or more) of the buttons for a set time period.M&MOC Committee Member - Archivist
I *think* this only works on later cars with orange clocks and the H & M buttons to the right of the display. You can switch between 12h and 24h by pressing the H & M buttons together. MGT#396 has such clocks and is currently set to 24h (for no particular reason).Last edited by G51 NAV; 23rd November 2011, 17:04.Regards
Glad I wasn't imagining that then!www.maestroturbo.org.uk - The Tickford Maestro Turbo Register
If you have orange clocks with the H&M buttons on the right of the display, you should be able to switch between 12h & 24h, as I explained above. I don't know when these clocks became standard across the board, but I thought all Montegos had this arrangement by 1990, if not earlier. My Today's Cars brochures from that era shows all Montegos with orange clocks.Regards
