digital clocks
  • digital clocks
    hello
    just a quick question is the digital clocks out of the vandem plas a straight fit in to a mg maestro turbo? if not what is needed. thanks.
    maestro turbo no 498
    It depends on the age, but the only difference with ones earlier than the turbo is plug and display size. But if it is a early one you can use the instrument surround with the turbo dash
      If you actually mean the entire digital speedo and gauge pack, the main thing you would need is the electronic speedometer sensor to fit into the gearbox instead of the mechanical cable.
      I believe that the Maestro and Montego sensor was the same as the one used on the Rover 800 range and possibly even some of the later Rovers (600, 400/45, 200/25) as long as they were fitted with the same type of gearbox ('PG1')
      You would then need to make up the necessary wiring to connect the sensor to the instrument pack.
      The rest of the dash wiring just plugs in to the Maestro MG/VP electronic instruments.
      If you want to use the trip computer as well, you will have problems making the fuel-related functions work, because working fuel flow sensors are hard to find nowadays
      1983 (Y) MG 1600
      1987 700 City 1.6 Van
      1988 Tandy camper 2.0D
      1990 Clubman D
      1990 MG 2.0i (spares donor)
      (all Maestros)
      Daily drive: Rover 25 GTi
        Not a straight swap, but not that hard to do. I've done it to my L series van project which is rather a lot more work!
          The r800 speed sensors do work to a point, but i altered an mg1600 one pigybacked to the back of an efi one
          As for the fuel flow transducer which the turbo would need,i do wonder whether these were fitted to some VWs as they are made by VDO who also make vw instuments and a lot of vws had trip computers
            Fuel flow transducer isn't worth bothering with to be honest.
              Its nice to have all featurs working though
                are these early or late ones?
                  There are only early ones aren't there?
                  Those clocks are out of an MG1600 not a vanden plas. Not that it makes any real difference though!
                    how do they differ from vandan plas ones?
                    thanks.
                      VDP have a blue rectangles background grid. MG1600's have a red one Very minor obviously!
                        thanks for that
                          You need the trip computer if you want a trip counter as the clocks themselves only have an odometer.
                          I once bought a brand new fuel flow transducer and fitted it to my MG1600 and it only lasted 3000 miles. Any second-hand one will already be broken.
                            so i need a fair bit more parts for it to fully work lol might just stick them back on ebay
                              would love a montego with digital dash, like a 1984 MG EFi. more functions like light check, vehicle map and even service interval indicator.
                              i will keep on looking.................................or dreaming i think
