Progress today.
AP Brakes conversion/MK3 golf coilovers
Very easy jobs to do.
Brakes first..
Step 1
Caliper carier (hub) remove old caliper and clean and box to be reused if i ever want to go back standard...i do this with all my parts i remove so everything takes twice as long and costs a bit more as i carry out any repairs to old parts at time if neded.
step 2
Dont modifiy calipers i removed a couple of mm on each bolt hole on the hub useing a large file took just a few minuites....left plenty of meet on them so no worrys there.
step 3
THE DISKS bolted it all up with 304mm disks to make my mind up how much to have them turned down decided on 298mm to be safe with clearence, got them back yesterday from machine shop and the whole lot bolts together like its OE.
step 4
Brake hoses still yet to do looks the easiest part of the job.
Coilovers..
Step 1 Remove old struts and springs both well past repairing so strait in the scrap bin.
step 2 Adapt top mounts used standard golf Bearings and the rest is all Montego and all fits together perfect.
Step 3 Bottom mounting bracket on coilover 1 of the holes need to be oveled a fraction to match the hub Bracket aprox 2.5mm,i adjusted the top hole as more land to play with.
step 4 The mounting point is to wide on the hub for the shock to slide over by know more than 1.5 mm, useing angle grinder with flappy pad just cut it back a bit at a time again just took a few minutes.
Step 5 Bolt it all together and stand back with a big smile on your face.
Any one thinlking of doing this dont be put of its got to be the easiest up grades i have ever done a day of pleasure..
I will add some photos just as soon as i have worked out how to do it.
Brakes first..
Step 1
step 2
step 3
step 4
Coilovers..
