The Gooon rebuild
Hi Benjamin - what engine is going in - T16 - O series?
The gooons looking well - nice to see her again?
cheers
mike...
Originally posted by Mike Brock View PostHi Benjamin - what engine is going in - T16 - O series?
cheers
mike...
My new rods arrived Monday. They were press fit pins so I have had them modified to take floating pins. Picked everything up from the machine shop today. I'm planning to fit an alloy flywheel with race clutch to get the rotating inertia down so once I get them I'll get the rotating components ballanced. Once done I'll be getting the engine built up.
I'm also just starting to look into fitting an internal slave cylinder for the clutch instead of having to use a lever.
Wow - your so lucky having all those T16 parts available off the shelf.
Work of art those cons - not cheap either. Looking forward to see gooon fire up once again.
mike...
You can use the external slave setup from the 620ti or 620Di which would be a simple bolt on/off swap.www.maestroturbo.org.uk - The Tickford Maestro Turbo Register
Originally posted by E_T_V View PostYou can use the external slave setup from the 620ti or 620Di which would be a simple bolt on/off swap.
The rods were on a clearence sale direct from Pauter in America so I managed to get them dirt cheap! For the price of getting the rods, getting them to the uk and getter mg them modified for floating bearings, it came to about half what it would have been to buy a set from the uk to begine with!
Hi Benjamin - nothing like a good bargain. Is it crankshaft next?
cheers
mike...
Originally posted by Mike Brock View PostHi Benjamin - nothing like a good bargain. Is it crankshaft next?
cheers
mike...
Next thing to buy is going to be the clutch and flywheel. So far it looks like I'm going to be getting an alloy flywheel with a 7 1/4" twin plate race clutch with alloy pressure plate. Clutch I'm looking at is rated for 400lb/ft of torque so should be ok for my needs.
If you are getting a twinplate clutch then the external slave is going to be fine (twinplate clutches need much less pressure than single plate ones).www.maestroturbo.org.uk - The Tickford Maestro Turbo Register
Originally posted by Turbo MG View PostMy crankshaft is ok to reuse and as they are ok for about 500bhp I'm just going to get it ballanced.
Yes it is.www.maestroturbo.org.uk - The Tickford Maestro Turbo Register
That's amazing So generally what can a turbo O-series bottom end handle. I thought is was believed to be 350?
