To change the O Rings on the carb you will first need to remove the saftey bolts. To do this you will need to cut a small grove into the top of the 3 bolts.
Then pull the auto choke off to reveal the O rings (2 of them in total)
Remeber to clean up the carb side in the hole too as it might have dirt and a little corrosion...
Hope this helps........
