It's dead easy as all the mounting points are there ready to go.
Specific bits of trim you will need (If you don't want to cut your existing trim) are the two 'end' parts of the rear parcel shelf. The small separate bits next to the rear quaterlights. You will also need the inner plastic C-post covers with holes in for the top mounting, unless you cut holes in your originals. Simply makes notes from the car you are removing them from (if applicable) or if you get stuck installing them, ask again on here for the finer details.
Cheers man. just found out where theres a saloon ( too far gone to restore ) where i can yeild a few spares and it has rear belts too So i'll give it a shot
