Montego fuel filler pipe
  • Montego fuel filler pipe
    Can someone confirm part number CRC9399 is a fuel filler pipe for a Montego?
    2002 MGZS 180. Cheap 50 car
    According to my info CRC9399 "fuel filler pipe" only appears on the Nov 88 on (vin 464731 on) microfiche and is listed as fitting "Montego 1600 + 2000EFI with fuel evaporation loss control". There is, however another type of fuel filler pipe assembly listed for the same engines vis WLP10227 (but NLA) for Vin 625639 to 636678. It says use WLP102610 (Vin 636679 on) along with fuel tank WFE 104600 and refer to T.I.B. No63 Issue 2 item137 for service fix only.
    Current Fleet
      Thanks Arthur. Xpart have these in Hinkley but you have to go through a supplier. Rimmers sell them for 143 each
        Unfortunately my estate falls into the later vin numbers and neither the filler pipe nor fuel tank seem to be available - lets hope i never need either!
        Current Fleet
          The only difference is in the length of the vent pipe and diameter. All fit
            thats good news - so can be "made" to fit if needed
            Current Fleet
ID:	320254 Did you get any from Hinckley Jeff .I was told they all will fit.I have CRC 9419 asy & another but not sure which .
              Sure & steadfast.
                I didn't want one David, hinckley is the main xpart distribution centre. new fuel filler pipes are possibly available from rimmers as I've said above. it's on their website. Vent pipes changed over the period as did the diameter due to unleaded petrol.
