gear linkage
  • gear linkage
    can anybody tell me if you can get new bushes and joints for the mg montego turbo gear linkage because mine is very sloppy
    Can't you get a generic one? I assume quite common on size
    1958 Ford Consul Convertible, new seats done, gorgeous
    1965 Ford Zodiac Executive. Put away for the winter
    1984 MG Montego EFi. Digital dash. Resto commences
    1984 MG Montego EFI. Digital dash putting together
    2002 MGZS 180. Cheap 50 car
      I haven't tried them, but Freelander with PG1 box should be very similar? or Rover 200 etc etc are definately the same... Rimmers seem to have the original ones anyway https://rimmerbros.com/Item--i-BNP9024. https://rimmerbros.com/Item--i-BNP9020. https://rimmerbros.com/Item--i-BNP2673 https://rimmerbros.com/Item--i-BNP9016 don't have the ball pivot any more https://rimmerbros.com/Item--i-BNP9018L but do have the spacer for it https://rimmerbros.com/Item--i-BNP9021L the universal joint at gearbox end is part of the rod, but can be cut off and replaced with a steering shaft uj if need be..
