What is this car worth?
I have been speaking to a guy in Scotland (A fair trot from here lol). He has a Monza Red 1984 MG Montego EFi with around 70K miles. He doesn't really want to sell but he said he may sell to me.
It has the digi-dash which all works & the interior is very good, has one small crack on the dash & the passenger seat may require a bit of foam to boost it a bit. The headlining is fine but the actual board has dropped a little.
Mechanically it is very good with anything that has needed to be done being done & a couple of things that are about to be sorted ( cam shaft seal I believe) & someting else.
Externally the rear wheel arches & door sills have recently been replaced but need painting properly, Bonnet has had a couple of holes in it but has been recomended to be replaced in the longterm as it is a bit weak, rear bumper has a very small crack in one corner, there is a bit of light rust under the O/S rear quarter window,fuel filler is very good, as are the "A" pillars.O/S drivers door has got rust in the corner but owner has a new skin for it.
To sort the body properly & for the best result appearance wise it will need to be re-painted though other than what is mentioned above there is very little if any other rust it's just there are a lot of local bits to paint & unless you do most if not all it will look like a patchwork quilt.
Any ideas on it's value
