New thread on this as we reach conclusion.
My new German a/r bar links came this morning, totally surprised as so similar size to MM, except barrel shorter and it has insulation rubbers - good thing, and won't rust like the MM original.
Will it fit? Just tried quickly and it does. Only problem is bush hole dia is 15mm same as MM bar end (MM bush dia is only 12mm hence it's tight fit).
In conclusion, needs either new bush with smaller dia hole or sleeve the new bush (or sleeve roll bar end). Fairly easy.
Note in one pic I put the German equiv rubbers and nut on the MM link
