Dash removal
  • Dash removal
    A little 'how to' as i've been asked quite a lot of times.
    This is from memory when I removed the dash from my Montego GSi as it rattled
    This is a how to remove the dash of a facelift Montego. Pre facelift is very similar
    Disconnect battery
    Remove cover from steering wheel centre
    Remove dust cover
    Loosen bolt and pull steering wheel towards you till loose
    Centralise wheel and remove bolt and wheel
    1997 Jaguar Xk8 Convertible. New cruiser
    2004 MGZT V8. Love this car
    2004 MGZT V8, project for the winter nearly done.
    Remove both sides of cowel and any 'anti rattle' material.
    Undo central screw only, do not remove.
    Pull towards you
    Remove both side connectors
    Remove unit
      Remove both top screws from dash cover
      Pull towards you and remove any connections to clocks, switches
        Undo the screws holding the display
        From under the bonnet, locate the speedo cable and push to inside the car
        Pull the display towards you
        Push the top connections off the display
        Pull the display more to get a hand behind it to remove the speedo cable. You need to push the white part to one side to unclip it.
        Remove the display
          Remove the 2 screws holding the cover
          Remove all connections to any switch etc
          Early models with black fusebox surrounds
          Remove the 2 bolts holding the metal strip and cardboard strip from under the display opening
          You will need to remove the steering column
          Pull down carpet etc to steering column bolt
          Undo the bolt connection from the steering rack
          Disconnect the ignition connection from the loom
          Undo the 4 bolts holding the steering column
          Remove the column by pulling towards you
            From behind the dash, remove the wire here in the centre
            Pull off the heater knobs
            Remove the screws behind
            Remove the display and disconnect
            Pre facelift
            Remove the cover from the small fan switch
            Disconnect the lamp
            Push out the fan switch and disconnect
            Remove the centre screw
            Push up the display and remove
            Centre the heater levers
            Disconnect the small display lamp just above the radio
              Remove both side covers under the dash
              Remove the fusebox cover
              Remove ashtray
              Remove Radio and unplug
              Pre facelift
              Remove the electric window switches and disconnect
                From the top of the glove box
                Remove retaining screws and drop down
                Unclip all connections
                Remove the glove box lock and light switch. Disconnect and push wires through to the rear of the glove box
                  Leave tidy in the boot with screws etc in the correct location
                  Note, you do not need to remove the glove box lid
                    Remove the side covers
                    Using a torx screw, remove 2 screws from each side
                    Pull out door seals
                    Remove covers
                    Remove centre bolt
                    Remove any loose things on the dash
                      Pull up from the bottom of the dash
                      Pull out dash from its position
                      If its on your car you can either disconnect the complete dash loom from the passenger front just under the dash or
                      Using long nose plyers, remove wiring clips
                      You should now be able to remove the dash from the car
                        While the dash is off you may want to fix the heater etc. Re-do the foam from the opening, sort any leaks from the heater pipes or sort any rattle
                        Prior to putting back in
                        These clips must be put back onto the dash.
                        When putting back in.
                        Make sure all wires etc are in the correct place
                        There is a pin in the top centre of the dash and a slot for it on the locating metal bulk head
                        Position the dash and push hard to locate the top clips then lower over the centre consul
                        Reconnect all
                          Jeff, you are a star! I'm doing this exact job tonight! Thank you!!
                            No probs and have fun with it
                            From memory your steering wheel nut is 33mm
                              An excellent how-to as usual
                              Another option that I take when removing the dash is to leave the steering wheel attached and remove the whole steering column as one piece.
                              Centre the steering
                              Remove the bolt holding the universal joint to the steering rack
                              Remove the 4 securing bolts that hold the steering column in place
                              Disconnect the wiring plugs (you may have to remove the cowl from the steering column to do this - I can't remember)
                              Remove the whole lot as one piece
