Rover 25 issues
  • Rover 25 issues
    Hi all
    My Girlfriends rover 25 1.4 (84bhp) is playing up at the mo unfortunatly.
    symptoms -
    it 'misses' on acceleration and sort of coughs
    also when its idleing, i can hear a clicking noise everyso often which coincides with the engine 'missing' or coughing.
    any help greatly appreciated
    cheers
    Ben
    Ugh, tell me about it...
    Does she run it low on fuel, ever? Mine clogged up and died on me yesterday, presumably due to being low on fuel and sucking up dirt from the tank. If so, you could try putting fresh fuel in and 'clearing it out' like I did.
    If not, when was it last serviced? The spark plugs might need cleaning/replacing...
    Not sure about the clicking but I've noticed this on our 1.8 K series, too.
      One problem me and the missus found with our old K series 400 was that around a year to 16 months after a service it would act the same as described and needed new plug leads.
      No idea why it did it, but once the leads where replaced all was well for another 12 months or so.
      In the end, we paid out for a top notch set of bosch leads which seamed to last a while longer (approx 18-20 months)before the symptoms arose again.
      Even changing the coil and plugs seamed to make no difference, it just 'ate' plug leads.
      Mal.
        As above from Mal, my 2 Metro Gti's both had misfiring problems and I gave them both a service complete with new plugs and leads. The leads seemed to be the problem (Insulation was breaking down on them), stick a new decent set on it and you should find the problem goes away.
          Hi all
          symptoms -
          cheers
          Ben
          Mine did that just thought is was because it was a rover so put up with it
          MG Maestro Turbo #500
          Rover 218 VVC Coupe
          MG TF
            thanks chaps
            im gonna sort it out tomorow whilst my missus is at work
            apparently there are two different set ups leads wise
            you have the two lead set up and 5 lead set up
            im assuming the 2 lead is for a coil pack and the 5 lead is for a dizzy?
            cheers all
              Is it sometimes reluctant to start from cold?
              If so it could be the Head Gasket. I have had alot of experience with HG issues on the K-series, and its not always obvious you have a HG problem until you see that the oil and water are the same colour!!
              I ended up fitting a LandRover designed K-series HG to my Rover 216 race car, and it has been totally reliable since.
              ***WARNING*** Don't use an MG Rover supplied HG (or eBay cr*p), the LR ones are the only ones that get rid of K-series issues, and they are only £23 for an LR dealer. The LR HG design will be featuring on all Euro4 K-series engines when NAC-MG release the new models next year.
              Neil
              90H Montego 1.6SL (LHD)
              94L Montego 2.0 Countryman TD
              01 MG ZS 180
              97 Nissan Primera 2.0GT
              16' BMW 330d M Sport
              14' BMW X1 25d M Sport
              57' Citroen Dispatch 1.6HDi
                Faulty crank sensor is another possibility.
                My name is Darren.
                Home of a Maestro for 30 years.
                1983(Y)Maestro 1.3 HLE (Nellie) Very poorly
                1995 Rover 214SI
                2004 MG ZS 120
                2006 LandRover 90 TD5
                2014 Volvo V40 T3 R-Design.
                  thanks all for help - turnt out to be one of the coil packs which was faulty
                  all sorted now with a new set of leads aswell - running perfectly
                  neil - thats interesting information there mate, all k series owner worth noting
                  thanks again
                  Ben
                    BTW a missus and a girlfriend, lucky man eh
                      :laugh: :laugh:
                      Steady on Jeff, your user title suggests likewise
                      My name is Darren.
                      1995 Rover 214SI
                      2004 MG ZS 120
