I hope this has worked ,Ive attached a file of a circuit diagram that I hope will reduce the signal to the speedo on a maestro digital dash.It looks like it can be calibrated as it has a variable resistor (is this a petentionometer?)
As ive said in another post im waiting for the fast check solid state instument tester to turn up so I may be able to sort things before fitting to car.
Russ
Russ
Tried the 820 transducer without the earth connected and it works reads 3-4mph high but I think a lot of speedos do. If earth is connected is doesnt work.
