Well, I have another project on the go on the drive. I collected MGT 381 on Saturday knowing it needs work but is a lot worse than I thought it would be.
A list of what it needs to be released onto the road is below, it is currently got mot until sept so I am planning on letting it loose on the local traffic next month if the repairs go well to make it legal at least!!
Headlining missing
Boost pipes loose
Headgasket failure
Water pump U/S
Alternator U/S
Boot rear panel has a hole big enough for me to touch the bumper through it!
Central locking stays engaged so it locks you in or out
Oil pressure light inop
Fuel pump blocked (gives about 5 mins of running then the fuel runs out)
Fuel pump constantly running
Old alarm system needs removing
A general tidy up of the panels to remove what's left of the rubbing strips
Locate missing body kit parts and refit them
Mixed size alloys
Headlining missing
Boost pipes loose
Headgasket failure
Water pump U/S
Alternator U/S
Mixed size alloys
