theres a firm in devon/cornwall area that sells new old stock Maestro windscreens. I found it on ebay
MG Maestro Trialing.
Well iv managed to split the new steering gaiter trying to get it to fit. Really tight fit when you cant get to them. only got the passenger one on cause the gearbox was out. So iv ordered a universal one so i can cut it to size. Iv made up a bumper bracket to replace the broken driver side one and have beefed up both of them to hopefully stop them sagging. Iv also slackened off the handbrake cable and iv ordered a pair of wheel cylinders so hopefully il have working brakes. Those adjusters will be the death of me.
Iv also ordered the headgasket aswell for when that job needs doing. Need a iron infusion tomorrow so hopefully il start feeling abit better and can get more done.
Brakes are sorted. Head ready to come off, well is off apart from the exhaust flange. I cant get to the 3rd stud easily. The other 2 have snapped off. But that wont be a problem when it removed to drill out. I was hoping the exhaust was just gonna come off at the ball joints.
The head bolts were very hard to undo. had to soak them in wd40.
Will have another go tomorrow when iv rested at that damn stud.
well after hours and hours i finally managed to get the manifold free from the exhaust flange so the head could come off. Yes they all snapped in the end so lots of drilling out tomorrow. The manifolds came off the head ok. The 2 end studs were rotton and fell off and one snapped in the middle. Gonna try the extractors tomorrow. hopefully they will help. My hand slipped yesterday disconnecting the last injector and it pulled the wire off Is it just a lucky guess when i solder the wires back on?
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
I spent ages filing down the exhaust manifold because it was corroded. Nice and flat and smooth now! the heads back on, so is the timing belt. Just gotta put the wires back on and water pipes, then fingers crossed that she'll start! I painted the metal pipe behind the head and also the servo as they had surface rust. Il take some more pictures tomorrow.
Got it all back together and running. Exhaust to manifold joint so il have to put some exhaust paste onit. New windscreen coming next wednesday at 9 £100 +vat tho. But will save me doing it. Struggling to get it into gear so looks like the box willbe coming out again as iv been playing around with different cables. Front bumper painted and fitted, so is the new rear door, just need some red paint, think the code is cne which is targa red. Bleed the brakes with the new cylinders tho the pedal reaches the floor. Replacement master cyclinder maybe? Great having a working handbrake tho.
Steve
Well the new windscreen has been fitted and the cars looking a million times better, thought i better paint up the wiper arms aswell. The exhaust manifold has started blowing again on the head so i have removed the engine this time to save taking the head off. Clutch is playing up again aswell. Needs a new release bearing and i think the fork is damaged from when the last one went. Engine was very easy for me remove this way. Iv twisted my ankle badly yesterday so slow progress at this moment in time. Tho im really keen to get back to it.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Iv just put the engine and gearbox in, im gonna clean out the radiator so have left this out for the moment. Still struggling for a clutch. Im thinking my spare cables are knackered aswell. To get it moving iv put a socket on at the lever end to take some of the slack out.
Now for sale?
MG Maestro Trial Car No RESERVE Classic Trials Austin Hill Climbe Road Rally
http://www.ebay.co.uk/itm/MG-Maestro...:SS:SS:GB:3160
Sell fell through which im seeing as a sign to keep her. Just need to make it really reliable.
Cars way of rewarding me was to decide it needs a new steering powersteering pump. It had a slight weep but the pulley has play to much play on it. So if any one has a good one going cheap I will be interested.
Steven
