MG Maestro Trialing.
Well i had car trouble during this trial so didnt finish it. I can post some pictures up of the worth but its being done as working car so probably wont be upto the standards of other maestro owners. Tho i plan to make it last. Iv primed the arches and seals today. Il post a couple of pictures soon.
Hi guys. Just a little bit of rust proofing that im doing. The car wont be going on the road yet but as i will be using it for trialing i thought id give it a go. The main areas that rust iv primed and painted with chassis paint as thats what iv got left over. Iv then given it a good waxoyl. Which should get into places where the brush cant. Its not perfect by anymeans but iv used the probe to get into the nocks and crannies so hopefully its a good start. Its had some welding done which dosent look great but its all solid. Im quite impressed with the car really. Anyway hears some of the pictures. The workshop is abit messy as the shed is full of hay so evrything is in here.
Iv just been out to put the second coat of waxoyl on. And the arches are looking great. Il see if i can take some good pictures tomorrow, Iv also put the rear shocks and springs on. Fitted a working one on the passenger while i was at it. Its gonna be weird not sqeaking all the time.
Just getting her back together. Shes having a full service im just letting the oil drain out over night. New air filter fitted new oil filter fitted. My new steering gaiters turned up today. Looks like theyre going to be pain to fit as it looks very tight, sure itll be fine tho. First trial is gonna be on 9th of feb. Really looking forward to it! Still got to fit the crank sensor aswell and il stick my spare rotor arm on aswell. Its getting there.
Getting there then, nicely doneOriginally posted by SteveMGprice View PostJust getting her back together. Shes having a full service im just letting the oil drain out over night. New air filter fitted new oil filter fitted. My new steering gaiters turned up today. Looks like theyre going to be pain to fit as it looks very tight, sure itll be fine tho. First trial is gonna be on 9th of feb. Really looking forward to it! Still got to fit the crank sensor aswell and il stick my spare rotor arm on aswell. Its getting there.
Plenty of scope to add some spacers to the rear shock tops to increase the ride height at the back if required. Thats essentially what they did with the streetwise after all.Originally posted by SteveMGprice View PostIv just been out to put the second coat of waxoyl on. And the arches are looking great. Il see if i can take some good pictures tomorrow, Iv also put the rear shocks and springs on. Fitted a working one on the passenger while i was at it. Its gonna be weird not sqeaking all the time.www.maestroturbo.org.uk - The Tickford Maestro Turbo Register
Yeah it is thanks. Its got spacers on the back and i have lowered it a little cause the last owner messed with it and it didnt have any rear shocks. Couldnt find anything about the streetwise shocks tho.
This morning iv changed the crank sensor the rev counter seems to work properly after doing this. Are they related? Still got the steering gaiters to do but that can wait for the moment. Its getting there weathers not on my side not normally a problem but the ramps have started creeping down so iv decided theyre not safe to use. Back to working on the floor lol. Iv also changed the oil and filter and the air filter. Thanks Steve.
Sorry guys been awhile since iv updated the thread. The clutch release bearing went on her. So shes been replaced with a ford ka that much better at the field trials aswell. But this means the maestro is just a little project but il still use it sometime plan is it to get it to mot standard soon. Iv bought a old fiesta for my road car and have still got loads to do on the land rover as usual. Really struggling with my health this year
So everythings a struggle. was the main using for using the ka for trialing at the moment. Hope your all enjoying the sun.
Steven
Well iv made a list of what i now needs doing to get it on the road.
New cooling fan
Front bumper making new mounts and adding ballst
Welding front crossmember, just finished that a moment ago
New windscreen, Gonna be really hard and expensive to find and buy
Lower arm ball joints each side
Swapping and painting rear door, tho not urgent helps keep motivation
Rear brakes need sorting, self adjusters not working
Properly fitting the off side steering gaiter, been a struggle with these
Maybe the wheel bearing tho it might be ok
Fixing damaged rear bumper and number plate lights
Attaching rear bumper, done yesterday
Fixing exhaust
Exhaust manifold gasket
Snapped off exhaust stud, probably head removal
Track rod ends
Rear shocks maybe.
Front number plate
