hi there i have a turbo van
ignition on heat light came on turned over the van nothing found there was no fuel getting to engine changed the fuel lift pump that was fixed went to start van no heat light on dash board wont start checked fuses seem ok but not sure how you no the transformer ones are not working is it something else can i by pass to test something??????????? thanx
