Brake wires
  • Brake wires
    The wires coming out from my brakes to a warning connector have perished
    and I need to replace them but I can not find the type or safe amp rating???
    (don't know the right word or term for it)
    I want to cut a length off the old wires, solder in new and heat seal it up.
    Does anyone know what wire I need and is it safe to get it from flea bay?
    (Motor factors round here are useless and pathetic)
    S
    why not just change the brake pads as they come with the wire already attached and do not cost to much if you look on e-bay
      Its the wire from the loom to the brakes that is
      missins, about fourinches worth.
      I have pared te wires in the protective sheath but
      I need to bridge the gap with the right wire.
        Those wires will carry next to 0 current, so any wire will be OK for the job.
        Ian
          As above anything will be fine. It'll carry no more than 0.5 amps in use.
            Thanks for that chaps, so no chance of me being
            zapped or frying the car!!!
              None what-so-ever. If you did short it out the worst that would happen is the dash light for pad warning would come on.
