Source for pistons
  • Source for pistons
    I have just been informed by the company doing the engineering work on my engine, that they are struggling to source some +010 pistons for the O series engine. Does anyone here know of anyone who may have these available?
    Also, I haven't seen anyone selling big-end bearings in regrind sizes. Again does anyone know if these are around (I'll admit I have checked Rimmers - its the next thing I'm doing!)
    TIA
    Club Secretary
    Might you get away with a light hone and a set of new standard pistons & rings? If so, I've a set going begging (cheap).
    midget1380@btinternet.com
      Thanks for the offer David, and that is what we had originally hoped for but the lip at the top of the bore is too much. I had hoped that +010 would be enough, but the standard piston oversize is +020 so I guess that it will be the same with turbo ones - if they are about!!!
      Club Secretary
        Hi Pete - you could replace the bore liners and fit David's pistons as another option.
          I like your thinking Mike. TBH, I was wondering about that as I wrote the reply to him. I'll raise it with the engineering company tomorrow and see what the possible cost could be......
          Club Secretary
            I know we have 2 or 3 new sets not sure what E_T_Vs intentions are with them.
            Rover 200 and 400 Owners Club (for wedge shape rovers, including coupe, tourer and cabriolet). - www.rover200.org.uk
              hi ya, a mate of mine has a brand new set of pistons for a O-series his names Stephen Collins if you need i can pm you his number i think he wanted as close as £140 for the set
                Bottom end bearings only came in 1 size though, if your crank needs more than a polish then you have no real option but to source another.
                  Thanks for these offers guys. Can you both let me know if they are standard or oversize and I'll get back to you over the weekend after I have spoken with the engineering company about all my options.
                  Countrydude - thanks for that heads up. With all these difficulties about what can be repaired and replaced I'm beginning to wonder if I should be looking for another engine
                  Club Secretary
                    If you go a different route, we have about 3 spare blocks & cranks etc. You'd need to PM EVO AL as he'll know condition etc.
                      From rover they came in only one size, but from aftermarket undersizes were available.
                        When I rebuilt my engine last year it was cheaper £75 for a new t series turbo crankshaft with all the new bearings still in the sealed Rover box.I got this from e-bay and was so pleased i got another One as a spare for my spare block in case i ever need to build it Back up as a spare engine
                          As I'm still getting used to the similarities and differences between these later (to me) engines, are you saying that the T series bottom end is the same as the O series?
                          Club Secretary
                            Yes it is identical.
                              With my search for pistons getting a tad frustrating although I still have a "couple of irons in the fire" I was wondering how much commonality there was between the Turbo pistons and those fitted to the M and T series engines. Knowing now that the bottom end is identical does the same hold for these?
                              Club Secretary
