been having fuel starvation problems with my efi.
when you switch the ignition on, pump runs for a few seconds to build pressure, then stops......correct.
therefore if you dis-connect the inlet pipe at the filter (to pump tank out), the pump should keep running, yes?
anyway, with the pipe off, pump ran for a few seconds and stopped.
have i got a problem somewhere else or am i missing something?
i've run a wire direct from the pump, via a switch, direct to the battery and the car runs alot better. i'm wondering if there is a fault with the fuel pressure switch? any way of testing it?
