Are all starter motors the same for 1.3 maestro `s through the years ? as I may need one .
Starter motor
i believe they are the same for the 1.3 and 1.6.. heres one on ebay
http://www.ebay.co.uk/itm/Rover-Maes...3D172235805330
regards rickyhome of the "mad maestro"
rover sterling kv6 and four tailpipes on lenso rs5's
1935 Morris 18/6 being rejuvenated with xj6 parts
Originally posted by thamestyres View Posti believe they are the same for the 1.3 and 1.6.. heres one on ebay
regards rickyMembership Secretary
Not quite correct as they have different part numbers between 1300 and 1600 versions (although 1300 and 1600 cold climates are the same!) and between early and late models (upto 86 and 86 on). Basic model type for 1300 is 8M90 and for 1600's is 9M90. HTH
Originally posted by maestro dave View Post
So putting aside the 1600 , are all 1300 maestro starters the same?Membership Secretary
